I need to replace the engine wiring harness connector (female) that connects to the Oxygen sensor connector (male). It has 4 color coded wires. When connecting those 4 color coded engine wiring harness into the oxygen sensor connector, does it matter where each color wire goes in which terminal? If it does matter, can you please supply a diagram or describe where each color wire specifically goes into which terminal? Thanks!
Jul 11, 2020 at 1:16 AM
