Overheats on freeway
327,000 MILES • 3.2L • 2WD • AUTOMATIC
MICHAEL BORELLI
Car slowly overheats while on highway. both cooling fans work, but not on high speed. Both fan winding's show a short between the yellow and green wires. I thought these were to be separate winding's.
Sep 1, 2019 at 1:45 PM
  • 110,248 POSTS
Welcome to 2CarPros.
If it is overheating at highway speed, this has nothing to do with the fans. Confirm the radiator isn't blocked with dirt and debris. Next, I need to know if there is any coolant loss. This could be related to a head gasket issue.
Let me know. If there is coolant loss, there check for leaks and check for a head gasket issue. Here are links to help:
https://www.2carpros.com/articles/coolant-leak-symptoms
https://www.2carpros.com/articles/car-is-leaking-coolant
Let me know what you find.
Sep 2, 2019 at 11:16 AM
