Overheating
195,745 MILES • 4.2L • 6 CYL • 2WD • AUTOMATIC
ROBERT MATTHEW MARTIN
I had to change the radiator because the nose for hose snapped off and a crack across radiator.it never overheated before until I change the radiator and it started overheating I thought the thermostat was bad so I changed the thermostat too. then I had to change the crankshaft position sensor because it's still running hot and I still haven't got it fixed yet. could I have a crack head or blown head gasket? there's no water in my oil, there's no white smoke coming out of exhaust pipe, there's no leakage under the exhaust manifold, there's no leaks coming out on the ground or the hoses. i checked the spark plugs, no coolant on the or in hole. but got bubble in radiator. not a lot of them but a couple here and there. i used bars leak head gasket sealer two cans, nothing, did nothing at all. what you think?
Jul 5, 2019 at 5:10 PM
SCGRANTURISMO
  • 4,897 POSTS
If you are having combustion gasses mixing with your vehicle's coolant then you probably do have a blown head gasket. Here is a link down below for you to go to:
Please go through this guide and get back to us with what you are able to find out.
Thanks,
Alex
2CarPros
Jul 6, 2019 at 5:30 AM
