overheating, replaced theromstat it was sticking
164,000 MILES • 3.5L • V6 • AWD • AUTOMATIC
WMITCHELL62
engine getting very hot, steam coming out but no leaks any where to be seen. Theromostat replaced as it was sticking but still issue. Does not happen all the time. Help!
Sep 10, 2015 at 11:56 PM
HMAC300
  • 48,601 POSTS
have cooling system pressure checked for internal leaks.
Sep 11, 2015 at 10:45 PM
WMITCHELL62
Thank you for your response of my 2004 chysler pacifica heating and cooling issue's! What does that mean if its a internal leak? is it water pump?
Thank you
Wendy Mitchell
Sep 12, 2015 at 12:10 AM
HMAC300
  • 48,601 POSTS
inernal leaks are like a head gasket/intake (most common) but could be other things like block or head crack which I don't think is the case here. also check radiator with fans disabled. check for cold spots as it should be warm/hot all over is cold spots radiator is bad.
Sep 12, 2015 at 2:22 AM
