overheating problem
JUSTUS2477079
I just bought a used 1997 bmw 740i . it keeps over heating and the brake light on the dash stays on what could be the cause of these issues?
Apr 28, 2013 at 9:29 AM
FREEMBA
  • 1,152 POSTS
For the brake light: Check the brake fluid level in the master cylinder reservoir. fill it to the FULL line.
Also, check the park/emergency brake pedal/lever to be sure it is completely released.
For the overheating: Check the coolant level (in the radiator).
Check the cooling fan fuses and relays in the underhood fuse box.
Finally, have the cooling system pressure checked for leaks.
Apr 28, 2013 at 9:41 AM
