Overheating-Problem
2006 CHRYSLER SEBRING
94,800 MILES
REVDO1
On my last drive, my thermostat temp increased, & once I stopped & checked, the radiator fluid was still contained in the radiator reservoir, & my radiator electric fans had stopped operating....Question: is there a fuse that operates the radiator fans, & why did my fluid stop circulating from the cold fill level....?..do I have to bleed a thermostat sensor, & I recently had my radiator serviced, & flushed, or do I have a clogged problem somewhere. what caused my fans to stopped working, & where do I start to check for troubleshooting this problem. 2006 Chry Sebring V6, 2.7 L..
Apr 20, 2013 at 11:52 AM
sounds like a bad thermostat.
hopefully you did not overheat it bad enough to damage the head gaskets. a leak down test will confirm
Apr 20, 2013 at 8:50 PM
