Overheating, oil leak, stalling when coming to a stop
170,000 MILES • 2.0L • 4 CYL • 4WD • AUTOMATIC
ROWDYBH18
Vehicle listed above is overheating. I have to fill up radiator every 30 minutes to an hour of driving. At an idle it gradually lowers in temperature. Radiator is few months old, radiator cap the same. The oil is splattered on top of engine valve cover,and behind the engine. It's idling very rough, stalling as it comes to a stop. Please help. Head gasket, converter?
Jan 18, 2021 at 11:08 AM
SEVAG P
  • 405 POSTS
First check if you can get ant fault codes. check below our guide.
perform visual inspection if any vacuum hose jumped out that can cause engine stalling and can leak some oil outside the engine.
Check our guides for how to fix engine stalling.
https://www.2carpros.com/articles/stall-at-idle
https://www.2carpros.com/articles/engine-stalls
Is the coolant level correct? radiator fans are working properly?
check the coolant reservoir any oil inside, or check the oil dipstick if any water found inside the oil.
check the links below our guides how to check overheated engine and head gasket check,
https://www.2carpros.com/articles/symptoms-of-an-overheating-engine
https://www.2carpros.com/articles/engine-overheating-or-running-hot
https://www.2carpros.com/articles/coolantantifreeze-in-the-engine-oil
Check guides and the diagrams below the procedure how to remove and reinstall cylinder head and perform valve timing.
hope this help, let us know what happens with you.
thank you.
Jan 18, 2021 at 9:58 PM
