overheating n shuddering when i accellerate
245,000 MILES
DAVID CLEMONS
Taking off from a dwad start n passing cars it starts to shudder or vibrate n now its overgeating when i press on the gas it shudders going up hills i dont know if its the suspension or its not getting enough i also have overheating problems ive changed the thermostat n it continues to overheat need help
May 29, 2013 at 4:41 AM
KHLOW2008
  • 41,812 POSTS
Overheating can be due to many factors and conditions under which overheating occurs would tell us the possible causes.
Do you have coolant losses issues?
When does the overheating occurs?
Were the spark plugs and related components checked for the shuddering/vibrations? If you have loss of power, that could mean misfiring. If no loss of power is noticed, that would mean a fault with the drivetrains, meaning axle shafts etc.
Jun 1, 2013 at 4:41 PM
