Overheating no leaks or white smoke
70,000 MILES • V6 • AUTOMATIC
ROBYN73
My daughter's car shows it is overheating when she stops. There are no leaks, damage, or white smoke. I was told to unplug something on the negative part of battery then plug back in to reset sensor. Does anyone know anything about this? Thanks
Oct 30, 2016 at 2:51 AM
HMAC300
  • 48,601 POSTS
no, check fuses and relay for fans and make sure they work kind of sounds like they are not. then check ECT sensor for resistance. see chart in picture for values.
Oct 30, 2016 at 8:41 AM
ROBYN73
Thank you for the help. I really appreciate it. You are correct. Apologies for my late reply
Dec 10, 2016 at 3:57 AM
