Overheating leaking water?
2001 FORD ESCORT
135,000 MILES • 2.0L • 2WD
JACKHOUSTON1968
The engine is leaking water from the front of the motor. not sure where exactly but was wondering if there was a freeze plugs or the location of freeze plugs.
Mar 23, 2023 at 8:25 AM
  • 110,240 POSTS
There isn't any right in the front. They will be on the sides of the engine block.
Where are you seeing the leak? I ask because the water pump may be going bad. It is run by the timing belt and can't be seen without the removal of the cover.
Take a look through this link and see if it helps locate it:
https://www.2carpros.com/articles/car-is-leaking-coolant
Mar 23, 2023 at 11:51 AM
