Vehicle overheating at idle or if stuck in traffic?
208,000 MILES • 3.4L • V6 • 2WD • AUTOMATIC
SHERWIN B
  • 7 POSTS
Vehicle overheating at idle or if stuck in traffic. i have changed the radiator, thermostat, and sensor. Both fans are working and hoses are fine, but still overheating. what else can i do to fix this problem? Please help.
Jan 6, 2020 at 6:41 AM
SCGRANTURISMO
  • 4,897 POSTS
Are you sure that the fans are turning on? This is usually why a vehicle overheats in traffic or idling. Please get back to us and we can go from there.
This guide can help
https://www.2carpros.com/articles/engine-overheating-or-running-hot
Jul 1, 2021 at 6:06 AM
SHERWIN B
  • 7 POSTS
Yes they are.. i hear/see them going even when i stop n turn the car off. could it be a relay or maybe i got a bad thermostat when i replaced it a couple months ago? because even while making those changes the overheating issue was still there.
SCGRANTURISMO
  • 4,897 POSTS
Hello again,
A bad thermostat would cause your vehicle to overheat all the time, as would a bad water pump or an air pocket that isn't allowing the coolant to flow. Did you change the fans at any point?
Thanks,
Alex
2CarPros
SHERWIN B
  • 7 POSTS
No I haven't changed the fans at all..i recently changed the thermostat.
SCGRANTURISMO
  • 4,897 POSTS
Hello again,
Well it wouldn't be the first time or the last time that a thermostat was bad right out of the box. I would suggest either replacing the thermostat again or testing it to make sure that it is opening. You can place it in a pan of boiling water. As it reaches the opening temperature, you can actually watch it open up. If it doesn't then it is bad. In the diagrams down below I have included the opening temperatures for your vehicle's thermostat. Please get back to us with what you are able to find out.
Thanks,
Alex
2CarPros
SHERWIN B
  • 7 POSTS
Okay, I will try that.. i really hope it's a bad thermostat.
  • 55,711 POSTS
This guide should help:
SHERWIN B
  • 7 POSTS
Thanks for the info, it really helped me understand the overheating issues ive been having.
  • 55,711 POSTS
Lets try a head gasket test first to see if that is the problem.
