Overheating issue
140,000 MILES • 3.9L • V8 • 2WD • AUTOMATIC
GLENN MORRIS
Okay so, the motor was rebuilt top and bottom at 76,000. Now after replacing the radiator, condenser, water pump, thermostat, heater control valve and have had the system bled numerous times it still runs hot. Done compression test twice and not a blown head gasket. Running out of things to change. Please help.
Aug 20, 2018 at 2:30 PM
Good morning.
A compression test does not verify a bad head gasket.
The leak down test is what confirms it. That is a test that injects air into the cylinder and you watch the coolant level in the cooling system. If you have a bad head gasket, the level will rise during the test.
That is the test that needs to be done.
Aug 20, 2018 at 6:44 PM
GLENN MORRIS
Thanks for getting back with me. The dealer did the first test and told me it was fine and there was air in the line. Then they showed me the air release valve under the coolant jug and how to bleed the air out of the system. Then about a week later it ran hot again on the highway. So I take it back to the dealer and they did a second test. and again they said it was fine. They did tell me to go by the Yellow Cab Global antifreeze. About a week after having it home again it started running hot on the highways if you get up to 70. If I keep it at 55 to 60 it just runs a little warm and if I turn on the dual climate control then the temperature gauge goes back to normal. So is the test that you are talking about something they would have done the second time I went in or would I have to ask for it specifically?
Aug 21, 2018 at 6:47 AM
I doubt it. They are missing the point. Air comes from somewhere. You should not have to bleed the system. The air could be coming from the head gasket leak.
They have not found the root cause of failure here at all. Surprised for a dealer.
Coolant type does not matter. The mixture does. It needs to be a 50-50 mix. One coolant will not make it run cooler than another.
Aug 21, 2018 at 7:25 AM
