Overheating issue
2009 BMW 328
128,000 MILES • 6 CYL • 2WD • AUTOMATIC
NASER NASER
  • 836 POSTS
I am aware this is common on these cars, a friend of mine has an 2009, he said it overheated, he got the dummy light so he stopped. He let it cool a bit and then drove, until he got home. Went to check it, no leaks, water is full, fan comes on for AC as well when engine temperature is at optimum. Checked with scanner, since these do not have a temperature gauge, coolant temperature and outlet are pretty close to each other, electric water pump rpm keeps fluctuating when driving, goes to zero all of a sudden and then a minute late goes back to average range, during that one minute the car overheats. pretty much a water pump issue or is it supposed to fluctuate like this?
Sep 7, 2019 at 12:09 PM
JIS001
  • 3,412 POSTS
Hi and welcome to 2CarPros. If you have the scan tool to see that data then you should see code for a water pump fault. It is a very common issue with electric water pumps on these vehicles to go bad. Even if there are no fault codes I would still suspect a faulty water pump.
Sep 7, 2019 at 6:26 PM
