1998 BMW 328 overheating
110,120 MILES • 6 CYL • FWD • AUTOMATIC
RIGLEAUTOMOTIVE
should you be able to stop the mechanical fan with your hand with engine running.I have a overheating problem and i suspect the fan clutch.I can literly stop the fan with my hand,does that sound right.TIA
Jul 13, 2009 at 7:02 AM
DOCHAGERTY
  • 9,606 POSTS
Replace fan clutch if suspect, if it is leaking replace it straight away. It has left hand thread.
Jul 15, 2009 at 1:33 AM
RIGLEAUTOMOTIVE
Thanks,I did replace the fan clutch and it repaired the problem.
Jul 15, 2009 at 2:23 AM
