overheating in traffic
20,000 MILES • 7.4L • V8 • RWD • AUTOMATIC
68 GOAT
I have the car listed above with a 455 aluminum two one inch flew radiator seven blade flex fan, transmission cooler 160 thermostat engine still runs hotter than it should. in traffic it runs 210 or better. not good for alder engines.
Apr 6, 2017 at 12:38 AM
CJ MEDEVAC
  • 11,000 POSTS
A few possibilities I can think of (others may jump in with more ideas)
No anti-collapse springs in the radiator hoses, sucking flat or close to it, tight bends
Radiator is not new/ maybe it needs professional flushing?
Is there a shroud for the fan?
This is just one of many products, have you tried any? Link below.
https://www.summitracing.com/parts/kys-530-4032?seid=srese1&cm_mmc=pla-google-_-shopping-_-srese1-_-keyser-manufacturing&gclid=Cj0KEQjwzpfHBRC1iIaL78Ol-eIBEiQAdZPVKsd_QNh-lcTJ6mhAdylZe_OptlnsKMZbU2ZI5IJwKlwaAp1F8P8HAQ
I reckon you have a fixed fan and are not using a fan clutch (fan clutch could be bad)
Here's another trick that may help.
See my last reply in this old post/ click on the pics and compare
https://www.2carpros.com/questions/1961-pontiac-other-1948-6-cl-getting-too-hot-215deg-just-blocks-driving
Your turn,
The Medic
Apr 6, 2017 at 12:35 PM
68 GOAT
Radiator is less than a year old, new hoses with springs upper and lower, fixed 7 blade flex fan, Appropriate ratio of coolant. I do have a shroud. I haven't ever tried the 40 Below... I will try it and see what happens. Thanks again for you help...
Apr 6, 2017 at 2:40 PM
HMAC300
  • 48,601 POSTS
coolant should NEVER be more than a 50/50 mix as it eats aluminum up.what is compression ratio on engine? if higher like 11-1 will cause it to run hotter, 210 isn't to bad to run a 455 try a bottle of water wetter, or the stuff for cooler running at auto parts that works. you may want to invest in an electric water pump as well.
Apr 7, 2017 at 12:02 AM
68 GOAT
Thanks for the info... I am trying a stuff call Purple Ice... Supposed to run 22 deg cooler...
Apr 7, 2017 at 2:46 PM
HMAC300
  • 48,601 POSTS
I've sued the coolant help stuff before and it works. not necessarily that brand though.
Apr 7, 2017 at 11:46 PM
CJ MEDEVAC
  • 11,000 POSTS
HMAC300, Took me a few seconds to figure out "sued" was spota be "used"!
I too have had good results with a different brand, called somethingoranother COOL or COOL somethingoranother, I couldn't find it online at the store I got it from a few years back.
The Medic
Apr 8, 2017 at 10:04 AM
