Overheating
HAMED GHADERI
  • 2002 HONDA CIVIC
  • 1.7L
  • 4 CYL
  • 199,000 MILES
When I start the engine in the morning and everyday I drive four and five hours in the morning. There is no problem with the car after four or five hours driving it starts acting up. The temperature goes up.I replaced thermostat, cap, all connections of the fans, crank shift position, water pump, but unfortunately mechanics do not know what the wrong is with this car. The oil level of the engine is good. No leaking, no mixture of oil and water, no low coolant, nothing. When temperature goes up I turn on A/C and the gauge stays under hot and whenever I speed up the gauge goes up and when I move it goes down. When I turn the heater on there is no hot blow, but when I accelerate the hot air comes out. I am really really fed up with this car. I do not want to spend more money. This car is really fuel efficient but I could have bought a Lamborghini if I did not buy this car. Please help me if know what is happening.
Thank you so much.
Wednesday, May 10th, 2017 AT 12:01 AM
HMAC300
  • 48,601 POSTS
When hot or warmed up check radiator for cold spots if any radiator is bad as it should be same temperature all over. Then pressure check and chemical test for coolant leak like a head gasket. Both are available at auto parts.
Wednesday, May 10th, 2017 AT 7:12 AM
HAMED GHADERI
Thank you for the answer. You mean when the temperature goes up a defective radiator must be completely cold when I touch every part of it?
Sunday, May 14th, 2017 AT 1:21 AM
HMAC300
  • 48,601 POSTS
No the radiator should be the same temp all across if you feel spots that are cold with your hand then the radiator isn't doing it's job.
Sunday, May 14th, 2017 AT 8:11 AM
HAMED GHADERI
Actually when the temperature was high I touched the radiator and it had the same temperature(not hot) all across.I don't know that should be like this?Is it normal?
Monday, May 15th, 2017 AT 10:18 PM
HMAC300
  • 48,601 POSTS
If it had the same tempp or felt like it then its ok. Have this pressure checked for a coolant leak like a head gasket.
Tuesday, May 16th, 2017 AT 5:36 AM
