Overheating (High Engine Fan not Working)
140,000 MILES • 3.6L • V6 • 2WD • AUTOMATIC
JUNG
My car is Gmc acadia 2009.
My engine is Overheating if vehicle is at stop because High Engine Fan is not Working. The same time, Aircon compressor is not working/shutting down due to high pressure. Can you please advise/help/give an idea how to correct/fix the issue with high engine fan? Thanks.
May 16, 2015 at 1:06 PM
WRENCHTECH
  • 20,760 POSTS
This is a pretty complicated fan circuit that utilizes 3 relays but someone is going to have to follow the wiring diagram to troubleshoot the problem. http://i1198.photobucket.com/albums/aa448/Wrenchtech/150716804.jpg.gif
May 16, 2015 at 10:26 PM
FAKHIR
  • 26 POSTS
My cooling fans are not working in high speed but working in low speed, when i remove the engine temperature sensor they got work in high speed it means that relays, fuses and fans are good, then what do you suggest to do here?
the radiator get so much hot and the A/C also comes to hot.
when i m driving then every thing is good may due to the fresh air.
please tell me what is wrong with this?
Aug 18, 2018 at 7:23 AM (Merged)
JUNG
I had the same problem with my Acadia 2009 I replaced the engine coolant temperature sender and it fixed it. Here is a guide and a diagram below to help you see how:
https://www.2carpros.com/articles/coolant-temperature-sensor-cts-replacement
Cheers
ASIMARSHID786
After removing thermostat and reinstalling it I final found this post and replaced the sensor all fixed.
RACHELSRN
My 2008 Acadia overheated but never marked hot. we added antifreeze when it cooled down and notice the cooling fans weren’t working. checked the fuses to make sure they were all good. pulled them out one at a time and put them back in. we then went to turn the car on to see if the cooling fans would come on and it was no crank, no start. any ideas?
Jan 2, 2021 at 9:57 AM
  • 55,616 POSTS
Based on the information provided, it's possible that the issue with your 2008 Acadia is related to the cooling fans not working, the overheating, and the subsequent no-crank, no-start condition. Let's try to break down the possible causes:
Cooling Fans Not Working: If the cooling fans are not functioning correctly, it can lead to engine overheating. The cooling fans are responsible for cooling the radiator and the engine when the temperature rises above a certain threshold. The fans should turn on automatically when the engine gets hot.
No-Crank, No-Start Condition: The no-crank, no-start issue can be caused by various factors, some of which may be related to the previous overheating problem:
Weak Battery: Insufficient power from a weak battery can prevent the starter from cranking the engine. If the engine overheated, it's possible that excessive heat could have affected the battery's performance.
Starter Motor Failure: The starter motor may have failed, preventing it from turning the engine over.
Faulty Ignition Switch: A faulty ignition switch can disrupt the electrical circuit needed to engage the starter.
Overheating Damage: In severe cases of overheating, engine damage can occur, leading to a no-start condition.
Here are some steps to help diagnose the issue:
Check the Battery: Test the battery with a multimeter to ensure it has sufficient voltage. If the voltage is low, recharge or replace the battery as needed.
Inspect the Starter Motor: Listen for any clicking sounds when turning the key to the "Start" position. If you hear clicking but the engine doesn't crank, it may indicate a faulty starter motor.
Test the Ignition Switch: Check if there is power at the starter solenoid when the key is turned to the "Start" position. If there is no power, the ignition switch may be faulty.
Check for Engine Damage: If the engine experienced severe overheating, there may be internal damage that is preventing it from starting. In such cases, a professional inspection is necessary.
Jan 6, 2021 at 1:22 AM
