Overheating front left brakes
120,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
SHADETREEGUY1
Front left brakes really hot after thirty minutes of driving. Replaced the brake hose and caliper and bled but is still getting hot. If I put in neutral it does not stop .
Apr 3, 2019 at 10:21 PM
Good morning,
Did you also replace the pads and the rotor? The rotor may be warped from the overheating and causing partial application of the brakes.
Apr 3, 2019 at 11:01 PM
SHADETREEGUY1
I have not, I wanted to make sure the problem was solved so I would destroy the new brakes and rotors.
Apr 4, 2019 at 12:11 AM
That is where I would start.
Apr 4, 2019 at 12:22 AM
