Overheating engine
257,000 MILES • 2.8L • 4 CYL • TURBO • 4WD • MANUAL
ANDREW MNKANDLA
The car engine temperature is higher than normal, and there is a burning smell coming from the engine. My mechanic said the smell is a sign of overheating engine.
Dec 16, 2019 at 12:09 AM
Good afternoon.
It may be a sign or may not be a sign. If you have oil burning from a leak, it will give you this smell.
https://www.2carpros.com/articles/engine-overheating-or-running-hot
What was his conclusion in his testing?
https://www.2carpros.com/articles/symptoms-of-an-overheating-engine
The most likely cause is low fluid or a thermostat. Has anyone checked it for you?
Dec 16, 2019 at 12:46 AM
