Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Toyota
4Runner
Climate Control
Heater
Not Working
Overheating but no heat
1987 TOYOTA 4RUNNER
3,500 MILES • 1.4L • 4 CYL • 4WD • MANUAL
TIFFANY TERRY - CROME
MEMBER
1 POST
Truck overheats, but no heat.
Dec 23, 2016 at 6:31 AM
STEVE W.
Experienced Mechanic
Could be a bad water pump or stuck thermostat, but I would lean more toward the pump. If the impeller has failed it will not circulate the water and you get an overheated engine and no coolant flow through the core gives no heat.
Dec 23, 2016 at 6:51 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
