Overheating but no heat
3,500 MILES • 1.4L • 4 CYL • 4WD • MANUAL
TIFFANY TERRY - CROME
Truck overheats, but no heat.
Dec 23, 2016 at 6:31 AM
STEVE W.
  • 15,409 POSTS
Could be a bad water pump or stuck thermostat, but I would lean more toward the pump. If the impeller has failed it will not circulate the water and you get an overheated engine and no coolant flow through the core gives no heat.
Dec 23, 2016 at 6:51 AM
