overheating brakes
272,000 MILES • 2.8L • 4 CYL • 2WD • AUTOMATIC
REDBONE
  • 105 POSTS
when I drive my truck about three to four miles my front right brakes overheat. I have replaced the brake pads. what would make them overheat in a short distance?
Mar 19, 2017 at 2:05 AM
HMAC300
  • 48,601 POSTS
a bad brake hose isn't releasing fluid, a frozen caliper or something is wrong with abs unit which typically happens when a brake job is done and not properly bled. if that's the case a mechanic will need to bleed brakes with a scanner to open valves on abs unit with a scanner then bleed system
Mar 19, 2017 at 5:05 AM
