When engine is cool it runs fine. When engine warms up it runs real rough. Also heater blows only cold air.
have changed the leads, plugs and coil pack. Have flushed the radiator.
what could be wrong with it
Monday, June 5th, 2017 AT 7:37 PM
KEN L
MASTER CERTIFIED MECHANIC
It sounds like you may have a blown head gasket. this will cause the heater not to work and the coolant to be low. Here is a guide to help you test to confirm the problem
