Overheating and low coolant light on
126,000 MILES
MS AREIC
I have a 1998 Monte Carlo Z34 3.8 egine and it overheats after I drive for about 20mins and when I turn the heat on there is no heat only cold air. I have noticed that the radiator fans are not working also. When the car starts to over heat it smells like plasic burning. What could this be because I know I have to let the car sit for about thirty minutes before I can get going again. When I put coolant in the thing that let's you know where the temp is never move again but the car starts smoking please help because I have no clue what it might be and I am not trying to get ripped off by a mechanic.
Jun 18, 2013 at 12:36 PM
CJ MEDEVAC
  • 11,000 POSTS
I'D SAY THE INOPERATIVE COOLING FANS WOULD BE A GOOD STARTING POINT
THIS COULD BE A SIMPLE FUSE OR RELAY
WITH YOUR CAR IN THIS CONDITION...............CONTINUING TO OPERATE IT WAS NOT A GOOD DECISION, YOU MAY HAVE CAUSED EVEN MORE SEVERE DAMAGE.....LIKE DAMAGE TO THE HEAD(S) OR OTHER STUFF
A SIMPLE $12 RELAY MAY HAVE TURNED INTO A $2000 REPAIR.........I'M JUST SLINGING OUT POSSIBILITIES
STOP DRIVING IT!.......GET IT PROPERLY CHECKED OUT!
https://www.2carpros.com/questions/2003-nissan-altima-gas-line-leak-near-tank-told-running-tank-tank-itself
I HOPE YOU ARE STILL IN THE "INEXPENSIVE ZONE"
RETURN TO THIS POST AND LET US KNOW WHAT YOU FIND OUT
THE MEDIC
Jun 18, 2013 at 1:40 PM
MS AREIC
Thank you for replying. I will keep you informed and I'm also thinking the same thing $2000 or more now.
Jun 18, 2013 at 2:39 PM
CJ MEDEVAC
  • 11,000 POSTS
MAYBE YOU WILL STAY IN THE LUCKY ZONE---YOU DID SEE MY LINK IN THE 1ST RESPONSE?
EVER THINK "JEEP"?
I HAVE A '46 AND A '77.......PROBABLY WON'T EVER NEED ANOTHER!
THE MEDIC
Jun 18, 2013 at 8:38 PM
CJ MEDEVAC
  • 11,000 POSTS
PICS WERE A NO SHOW===I TRY AGAIN
Jun 18, 2013 at 8:43 PM
