Overheating and coolant loss
135,000 MILES • 2WD • MANUAL
DECLAN MCGOVERN
I have had my vehicle for six months and twice now on long journeys the engine overheats and loses power. the header tank is empty so i fill it up but an hour later the same thing happens and the tank is empty again. it only happens on long journeys could someone please help? it is really putting me off as i love the car.
Oct 8, 2017 at 6:57 AM
STEVE W.
  • 15,415 POSTS
Sounds like a failing radiator or water pump. The coolant just cannot keep up with the heat generated. Using an IR thermometer to check the temperatures across the radiator would show if this were the case.
Another cause of this same issue would be a partially plugged exhaust. That traps the heat in the engine and slowly overwhelms the cooling system.
An exhaust back pressure test would show if that was the case.
Oct 8, 2017 at 7:42 AM
