keeps overheating and I’ve already replaced the thermostat?
160,099 MILES • 6 CYL • 4WD • AUTOMATIC
KAYTLYN SHADLEY
It keeps overheating and I’ve already replaced the thermostat and the sensor yet it’s still overheating.
Mar 23, 2021 at 8:00 AM
  • 110,251 POSTS
This could be a few things. First, if it only happens when you are in stop and go traffic, it could be the cooling fan isn't working. Also, it could be the radiator is partially plugged and needs to be flushed. Or, it could be even a head gasket issue.
Here is what I suggest, if it is only happening when in stop and go traffic, pay attention to see if you can hear the cooling fan operating.
If the fan is working, check to make sure the radiator is clean inside and not corroded. Here is a link that shows how to flush a radiator:
https://www.2carpros.com/articles/coolant-flush-and-refill-all-cars
If the radiator is clean or if you have already flushed it, follow the next link to determine if it could be related to a bad head gasket.
______________________________
Let me know what you find or if you have other questions. Also, let me know how quickly it overheats and if you actually see steam from under the hood or hear the coolant boiling.
Jul 1, 2021 at 6:06 AM
