Car has been on and off overheating alot the past year or two?
89,000 MILES • 4 CYL • 2WD • AUTOMATIC
PAIGEENSTALL
Car has been on and off overheating alot the past year or two. Has been flushed, thermostat replaced a while ago and a couple of weeks ago, the fan replaced..
My next guess was the coolant temperature sensor? Recently it has been overheating again.
I do believe it has been doing worse on gas mileage. And a while ago I had to replace spark plugs because one of them was burnt up to the point it caused the check engine light to come on. Idles rough. Hesitates to start. Bubbling noise from over flow.
May 2, 2018 at 12:04 PM
CARADIODOC
  • 34,415 POSTS
Replacing the sensor will not fix anything. It is just reporting the overheating, not causing it. Much of what you described could be attributed to a leaking cylinder head gasket. Before you keep running in circles and get "wrapped around the axle", have your mechanic perform a chemical test on the head gasket. That involves drawing air from the radiator, while the engine is running, through a glass cylinder with two chambers partially-filled with a special dark blue liquid. If combustion gases are sneaking into the cooling system, that liquid will turn bright yellow.
That air that can leak into the cooling system can pool under the thermostat. That will cause it to not open and the engine will overheat. Thermostats must be hit with hot liquid to open. Hot air will not do it.
If the test is positive for a leaking head gasket, no other attempts to solve the problem will be successful. The head gasket will have to be replaced and the cylinder head must be checked for pitting to be sure that will not happen again. If there is no indication the head gasket is leaking, we will need to look at some other possible causes for the overheating.
Jul 1, 2021 at 6:27 AM
PAIGEENSTALL
Changed the coolant temperature sensor and so far has fixed the problem.
