Intermittent overheating issue
115,000 MILES • 1.8L • 4 CYL • AUTOMATIC
ALLAOUA
My car is overheating sometimes. It is overheating after driving a while. The coolant system is good. The fan is good. There is no leak. The oil in the engine is good, not mixed with coolant fluid.
I have no idea about this problem.
Jun 6, 2022 at 2:00 AM
  • 55,688 POSTS
I would use a garden hose and blast the dirt etc,. from the front of the vehicle because the fins of the radiator get clogged up, also here is a guide to help you see what I am talking about. Plus replace the radiator cap or have it checked because if it isn't holding pressure the engine will overheat.
https://www.2carpros.com/articles/engine-overheating-or-running-hot
Jun 6, 2022 at 1:14 PM
