Overheating
204,000 MILES • 3.0L • 6 CYL • 2WD • AUTOMATIC
FELICIA BLEDSOE
I was accelerating my motor trying to get unstuck in the snow and the engine overheated. I removed the thermostat and the engine is still overheating. Within about 10 minutes of driving. The water is overheating the reservoir gets low but I don't see any signs of busted hoses or where the water is going.
Feb 20, 2021 at 2:12 PM
  • 110,248 POSTS
If the engine was overheated prior to this happening, we need to make sure it isn't related to a bad head gasket. You indicated you don't know where the coolant is going, so we need to check.
Here is a link that explains how to check for a bad head gasket. Do the things it indicates and let me know the results.
Take care and God Bless,
Feb 21, 2021 at 9:18 AM
