Overheating
281,000 MILES • 4 CYL
NIKKIHONDA2002
So i just bought this yesterday. it started up just fine and it is quiet. I drove the car home and i noticed when i opened the hood of the car that there was antifreeze everywhere. Funny thing is it was coming from the over-flow part . Now at this point i am thinking that it is because of the top not being on there tight but to my surprise it seemed like that was the wrong top. Any who , i take the car to my mechanic he said that there was no visible leaks and that maybe it is the radiator cap because it was burned. So he told to go get another cap and see if that works. Sadly it did not because i was on my way to work and it did it again. But its not showing on the dashboard that it is running hot.
Apr 20, 2017 at 8:29 AM
HMAC300
  • 48,601 POSTS
have coolant system pressure checked for a coolant leak like a head gasket or you can do it your self and rent at auto parts there is also a chemical additive you can put in. either is fine. it may be possible there is air stuck in system as well causing it.
Apr 21, 2017 at 12:06 AM
