I changed the thermostat and fun clutch and it is still overheating. What do you think can be the problem? Thanks
Sep 2, 2018 at 1:04 AM
AL514
✓Experienced Mechanic
Hello, thanks for using 2CarPros.com. There is a few thing it could be, and by taking some temperature readings around the radiator and coolant hoses if you have the means. You may have something going on with the radiator or head gasket. Is the truck losing coolant at all? Are you having to add it all?
