overheating, how to replace the internal water pump shaft?
100,100 MILES • 2.0L • 4 CYL • TURBO • 2WD • AUTOMATIC
PARIS MULLINS
How hard is it to change the internal shaft for water pump?
Feb 22, 2022 at 12:12 AM
Can you take a look at this diagram? I assume you are looking at number 18.
We don't have a process in the manual on how to remove this shaft specifically but instead on how to replace the pump.
I am attaching this process as well for your review.
Also, here are a couple of guides that will help with doing this repair:
https://www.2carpros.com/articles/coolant-flush-and-refill-all-cars
You will want to pressure test the system afterwards:
https://www.2carpros.com/articles/radiator-pressure-test
Please run through all this info and let us know what else you would need. Sorry we didn't have the exact info you were looking for.
Feb 23, 2022 at 9:21 AM
