Overheating
81,000 MILES • 1.6L • 4 CYL • 2WD • AUTOMATIC
MIKE6614
Replace the radiator and the thermostat. The car runs for a little while expansion tank starts bubbling.
Oct 26, 2018 at 10:43 AM
  • 110,251 POSTS
Based on your description, I need you to check for a head gasket issue. If you are getting air bubbles into the cooling system, there is a chance the gasket has failed.
Take a look through this link and try the tests listed.
Oct 26, 2018 at 11:50 AM
