Car will not overheat if I run it in the driveway but as soon as I drive it it overheats. Replaced thermostat, water pump, coolant temperature sensor. Fans work, not loosing coolant no oil in coolant or coolant in oil runs great. The A/C condenser had a small impact so it is pushed up against radiator. can lack of airflow cause overheating. Other ideas are clogged radiator or heater core.
Feb 4, 2017 at 12:30 PM
