Hi viencnet,
There are a few items that can cause the problem.
1. Radiator Fan control sensor, located at lower right side of radiator. Check if it is connected. Unplug the connector and use a jumper across the terminals. Turn ignition switch ON and if the fan runs, the sensor is faulty.
2. Radiator fan control module. Turn On A/C and if fans do not come on, this item coudl be faulty.
3. Fan control unit. Testings would have to be done to determine if it is faulty.
SPONSORED LINKS
Saturday, September 4th, 2010 AT 2:34 PM
