Overheating
145,966 MILES • 3.9L • V8 • 2WD • AUTOMATIC
JULIAN ADAME
  • 7 POSTS
My car overheats when driving but not in idle. Heater will not blow hot air. It lacks pressure but it builds up after a while. It is not leaking coolant and head gaskets are perfectly fine. I replaced thermostat. Overflow thank will not go down sometimes and it looks like it has no water in the engine coolant thermostat housing assembly.
Dec 10, 2017 at 6:11 AM
JIS001
  • 3,412 POSTS
First you need to verify you did not get an air pocket in the cooling system. Here is the procedure for bleeding. First pic is the air bleeder. Second pic is the heater bleed. Here are the instructions
Filling-Bleeding
On 3.9L engines
Remove the engine fill cap.
On 3.0L engines
Open the engine air bleed.
On all engines
Open the heater air bleed.
Add coolant to the degas bottle allowing the system to equalize until no more coolant can be added.
On 3.0L engines
Close the engine air bleed when coolant begins to escape.
On all engines
Replace the degas bottle cap.
CAUTION: Care must be taken to ensure the accessory drive belt does not become contaminated with engine coolant.
On 3.9L engines
Add as much coolant as possible to the engine fill. The heater air bleed will remain open.
Replace the engine fill cap.
On all engines
Note: The heater air bleed remains open.
Start the engine and turn the heater to MAX position.
Close the heater air bleed when a steady stream of coolant comes from it, during engine idle.
Allow the engine to idle for five minutes, add coolant to the degas bottle as needed to maintain the cold fill MAX mark.
Reopen the heater air bleed to release any entrapped air and close again.
On 3.9L engines
Maintain engine speed of 2,000 rpm for 3-5 minutes or until hot air comes from the heater.
Return to idle and verify hot air is still coming from the heater.
On 3.0L engines
Maintain engine speed of 1,500 rpm for 3-5 minutes or until hot air comes from the heater.
On all engines
Set the heater temperature setting to 24°C (75°F) and allow the vehicle to idle for two minutes.
Shut the engine off and allow to cool.
After the engine has cooled, add coolant to the degas bottle to bring the level to the cold fill MAX mark..
Dec 10, 2017 at 7:32 AM
JULIAN ADAME
  • 7 POSTS
I cannot find the heater bleed.
Dec 10, 2017 at 8:21 AM
JIS001
  • 3,412 POSTS
According to the diagram, it looks like it is on the driver side firewall. Looks like next to bottle. Here is another picture with the cowl off.
Dec 10, 2017 at 8:48 AM
JULIAN ADAME
  • 7 POSTS
The one from the first picture?
Dec 10, 2017 at 8:51 AM
JIS001
  • 3,412 POSTS
The second picture. If you cannot find it try to bleed from the bleeder in the first piture. Turn heater on. When a steady flow of coolant comes out, shut vehicle off and let it cool down and repeat the step if you see the level drop in the bottle.
Dec 10, 2017 at 8:56 AM
JULIAN ADAME
  • 7 POSTS
Do I have to open the engine fill as well?
Dec 10, 2017 at 9:25 AM
JIS001
  • 3,412 POSTS
Only to fill with coolant.
Dec 10, 2017 at 10:57 AM
JULIAN ADAME
  • 7 POSTS
Does it matter if I use green instead of yellow?
Dec 13, 2017 at 9:27 AM
  • 55,710 POSTS
Yes only add yellow. Please let us know if this fixes it.
Cheers, Ken
Dec 17, 2017 at 7:32 AM
JULIAN ADAME
  • 7 POSTS
I've been filling it with conventional green. What's the difference?
Dec 17, 2017 at 7:51 AM
  • 55,710 POSTS
They can mix and cause coagulation but in most cases you will be okay.
Dec 18, 2017 at 3:28 AM
JULIAN ADAME
  • 7 POSTS
That's the only thing left that might be causing overheating. I replaced termostat, water pump, radiator, I checked head gaskets and they were good. I bled the coolant system, replaced heater valve and heater core and overheating problems prevail, the heater won't work and it has no leaks.
Dec 18, 2017 at 3:44 AM
  • 55,710 POSTS
Unfortunately the head gasket chemical test is only about 75% accurate you can still have a blown head gasket. Lets try this remove all of the spark plugs to check if one or two of them look different than the rest. This will be the induction of a change in the combustion chamber.
Because the heater core fills with air and you constantly need to add coolant is a sign of a blown head gasket.
Dec 18, 2017 at 4:34 AM
JIS001
  • 3,412 POSTS
Did you ever find the heater bleeder? Also you may want to try a new expansion tank cap if you have not replaced that yet? And as Ken suggeted, remove the spark plugs and see if anyone of those look different? You may need to do a cylinder leak down test.
Dec 18, 2017 at 12:40 PM
