Overheating puddle of coolant on the ground ?
200,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
COURT93MCGEE
I noticed my car was starting to overheat it stayed right above the middle temperature (higher than normal) when I got home and turned my car off I had a puddle of coolant on the ground but my reservoir was still filled what can be the issue? Some one said water pump?
Feb 3, 2026 at 2:28 PM
  • 55,560 POSTS
That could be but can I ask if when this is happening do you hear the radiator cooling fan working? If not this will be the issue, the cooling fan motors go out when you have this many miles on the car. But, if there is a leak and you need to keep refilling the reservoir then the leak will be the issue. If you cant see where the leak is rent a pressure tester from the auto part store (free) and watch this video to help you find the leak
https://www.youtube.com/watch?v=W8kra65m15c
Please upload a short video in your response of the problem, so I can see what's going on. Ken
Feb 3, 2026 at 11:52 PM
