Overheating and overflow tank is leaking
135,000 MILES • 3.8L • V6 • 2WD • AUTOMATIC
ALEXTTT
  • 59 POSTS
My car begin overheating and I noticed that the overflow tank hose was leaking a lot. Will this leaking hose for the overflow cause my car to overheat?
Feb 21, 2020 at 8:33 AM
Good evening,
If the coolant level in the radiator goes low, yes it can.
https://www.2carpros.com/articles/engine-overheating-or-running-hot
Did you verify the coolant level?
https://www.2carpros.com/articles/radiator-pressure-test
It could be the thermostat. I would replace it to be sure. It is simple to replace.
Feb 21, 2020 at 8:43 AM
ALEXTTT
  • 59 POSTS
How do I bleed the system?
Feb 21, 2020 at 8:51 AM
Run the engine at 1,200 rpm's and watch the coolant level and add as needed. When you get heat there is no more air. Put the cap on and take it for a ride.
Feb 21, 2020 at 9:07 AM
ALEXTTT
  • 59 POSTS
Do I need to unscrew the screw on top of thermostat ?
Feb 21, 2020 at 9:29 AM
You can while filling the coolant but not when it is running.
Feb 21, 2020 at 9:46 AM
ALEXTTT
  • 59 POSTS
So just keep topping it off from the radiator until it's full?
Feb 21, 2020 at 10:01 AM
Correct. Run it at 1,200 RPM's with the cap off and add as needed. When you get heat, the air is out of the system. Then install the cap and let it idle.
You will need a second person for this.
Feb 21, 2020 at 5:18 PM
