Overheating replaced the fan motor and relay?
100,000 MILES • 4 CYL • 2WD • AUTOMATIC
SKOOTER28
  • 98 POSTS
I have replaced the fan motor and relay and temperature sensor and head gasket thermostat and water pump and all and car still overheats when at a stop sign.
Jun 24, 2025 at 3:33 AM
  • 55,710 POSTS
Yep, I would swap out the radiator, it sounds like it has blockage either internally or externally. This guide can help:
https://www.2carpros.com/articles/engine-overheating-or-running-hot
Before you take it apart, I would do a chemical test to make sure you don't have a cracked block. Please go over this guide as well:
Please go over these guides and get back to us.
Jun 25, 2025 at 4:12 AM
SKOOTER28
  • 98 POSTS
But when driving it doesn’t overheat. what happens is when it gets hot the fan kicks on then right after it shuts off before it cools down.
Jun 25, 2025 at 4:27 AM
  • 55,710 POSTS
So when it gets hot the radiator fan kicks in and then it cools down?
Jun 25, 2025 at 11:15 AM
SKOOTER28
  • 98 POSTS
When the temperature gets hot the fan kicks on but doesn’t stay on long enough to cool car down pretty much it kicks on for a little bit then cuts right off and car will over heat if I’m stopped but if I’m driving it doesn’t overheat I’ve replaced the fan itself and everything with it relay switch and everything else I named them the last thing I replaced was the temperature sensor thinking that was it but it still does it.
Jun 25, 2025 at 11:18 AM
  • 55,710 POSTS
Okay, I got it, since you replaced the major players in the system the only thing left is the PCM. You can get a preprogrammed unit by searching Google or Ebay which should fix the problem. The only other thing I can think of is that the engine was a cracked block. Did you do the chemical test?
Jun 26, 2025 at 1:56 AM
SKOOTER28
  • 98 POSTS
I replaced the head gasket everything was good with that.
Jun 26, 2025 at 1:59 AM
SKOOTER28
  • 98 POSTS
How do you do the chemical test?
  • 55,710 POSTS
This is how:
Please go over this guide and get back to us.
Jun 26, 2025 at 2:53 AM
