Start with a chemical test at the radiator for a leaking cylinder head gasket. Combustion gases will push coolant into the reservoir, and if those gases pool under the thermostat, that will prevent it from opening, then the engine will overheat. Thermostats must be hit with hot liquid to open. Hot air will not do it.
SPONSORED LINKS
Friday, April 13th, 2018 AT 6:56 PM
