Overheating?
200,000 MILES
POLK
  • 8 POSTS
My car has been overheating but i couldn't find where it's been leaking. So, someone took out the thermostat, but it's still been leaking, and I barely used a pressure tester in it. in the video, I attached that's where I can see the coolant at but is it just the thermostat housing or something else also?
Jul 19, 2023 at 2:23 PM
  • 110,246 POSTS
Based on what I see in the video, it appears to be the thermostat housing gasket that is leaking. As far as the thermostat being removed, that doesn't always work. A new one, along with a new thermostat housing gasket should be installed.
Here is a link that explains how it's done:
If you provide the engine size, I can get you the directions specific to your vehicle for replacement.
Jul 20, 2023 at 12:34 PM
