Overheating
328,424 MILES
ZUL
Few month ago my vehicle was overheating so manage to send to workshop. then when my friends while using it it is overheating again. when i opened the spark plug there is water going out from the spark plug.
May 29, 2019 at 10:20 AM
  • 110,248 POSTS
Welcome to 2CarPros.
Correct me if I'm wrong, but if you remove the spark plugs, coolant is coming from the engine/spark plug hole? If that is the case, either you have a crack in the head or engine block, or a blown head gasket. When running, are you seeing excessive white smoke from the exhaust?
Take a look through this link and let me know what you find.
May 29, 2019 at 1:37 PM
