Overheating, fan does not seem to kick on
2005 MINI ONE
105,000 MILES • 1.6L • 4 CYL • 2WD • MANUAL
BRADHAGGER
Hi, my car has been sitting on the drive since November and late January I went out to it to see if it was alright to go through and mot, but then it started to overheat and flash on the red line on the temperature gauge. I’ve changed the thermostat and the sensor as the fan doesn’t seem to kick in. It uses so much coolant but I don’t see any liquid dripping from the bottom of the car. I wonder if you could give me any advice on what it could have been. My old man knows a fair bit about cars but he doesn’t see why the fan one kick, he suggest it could be the fan resistor but still unsure.
Mar 13, 2021 at 3:24 PM
Good morning,
The first thing to need to do is pressure test the cooling system for the leak.
https://www.2carpros.com/articles/radiator-pressure-test
Check the oil for any coolant present in the oil pan. If you have coolant, that would indicate a possible head gasket leak.
https://www.2carpros.com/articles/engine-overheating-or-running-hot
Mar 13, 2021 at 4:49 PM
