Overheating
190,000 MILES • 3.3L • 6 CYL • 4WD • AUTOMATIC
KENERO
Inlet pipe that goes back to engine from lower radiator hose broke and I replaced. While housing was off thermostat was right there so I decided to change. After replacing, van started overheating. Thermostat goes in only one way, right? Anyway cannot seem to locate problem, leaning towards a clogged radiator. I appreciate any feedback because this one got me.
Sincerely,
Ken
Nov 19, 2018 at 12:31 AM
JONNYB1963
  • 263 POSTS
Hi Ken,
Yes a thermostat could be installed backwards and if so, could cause the behavior you are seeing. One thing I would like to ask is, is the electric fan working?
It sounds like everything was okay prior to the hose change so if that is true, I would double check the installation of the thermostat.
Also see the link below.
https://www.2carpros.com/articles/engine-overheating-or-running-hot
Jon
Nov 19, 2018 at 12:56 AM
