Overheating
2010 FORD BANTAM
185,000 MILES • 2WD • MANUAL
COURAGE MARAVANYIKA
I have a the vehicle listed above and it is overheating after driving it for about 20km or more, what is the problem and what causes it? Thanks for help.
Jun 17, 2020 at 5:55 AM
Good morning,
This could be a thermostat. If it is not opening, there will be little or no circulation.
Make sure the coolant level is correct. Also, check and make sure the fins in the radiator are not clogged with debris.
https://www.2carpros.com/articles/symptoms-of-an-overheating-engine
https://www.2carpros.com/articles/engine-overheating-or-running-hot
Jun 17, 2020 at 6:26 AM
