Overheating
200,000 MILES • 3.0L • 2WD • AUTOMATIC
ROBROSRIO
I've been rebuilding the car listed above. For some reason I can't get it to stop overheating. I replace the thermostat, water pump, thermostat housing, radiator, radiator cap and the heater core and yet the car keeps overheating. I bled the system as best as possible to make sure there was no air in the system. I make sure to check and see if there was a blown head gasket and there wasn't. honestly I'm really at a loss and I need some help.
Apr 20, 2019 at 1:13 PM
SCGRANTURISMO
  • 4,897 POSTS
Have you done a flush and fill to clear out any crud that might be plugged in the water jacket somewhere preventing the coolant from circulating yet? That is really about the only thing I can think of as most of your vehicle's cooling system is new. I have included a link down below for you to go to:
https://www.2carpros.com/articles/coolant-flush-and-refill-all-cars
Please go through the guide and get back to us with what you are able to find out, please
Apr 20, 2019 at 2:11 PM
