Overheating when idling
160 MILES • 1.7L • 4 CYL • 2WD • AUTOMATIC
BRITTBRITTD91
I’m having overheating problems. I’ve replaced the thermostat, the radiator and the radiator cap. The car seems to overheat when I’m idling. No smoke, fans kick on.
Apr 29, 2019 at 1:28 PM
SCGRANTURISMO
  • 4,897 POSTS
This sounds like you might need to do a flush and fill on your vehicle's cooling system. Over time your vehicle will get scales and muck that will collect in the water jacket and the heater core and radiator that will restrict the flow of coolant. You can clean the whole system by doing a flush and fill. I have included a link below for you to got to:
https://www.2carpros.com/articles/coolant-flush-and-refill-all-cars
Please go through this guide and get back to us with what you are able to find out.
Thanks,
Alex
2CarPros
Apr 29, 2019 at 4:08 PM
BRITTBRITTD91
Thank you for the information. If you wouldn't mind I would like to go into better detail just so you have a better understanding. The car is a 2002 Honda Civic LX with about 150,000 miles on it. The first sign of overheating actually happened in the city, stuck in traffic. It seemed to be overheating while idling. I went and bought a new thermostat. Problem went away for a while. Overheating came back, only while idling or the car just sitting or at low temperatures. Bought a radiator and a radiator cap and replaced both. Problem was still there. Replaced the clamp that holds the main hose, thinking that was the problem because it looked damaged... car ran fine for about a month.. then started overheating again. I removed the thermostat about a week ago thinking the weather is warm, i don't need it and maybe it was a faulty thermostat all along. Been driving fine for 2 days without the thermostat, now it's over heating again! I went and replaced the temperature sensor, still overheating. When it overheats there is no smoke.. the cars temperature gauge just climbs up all the way up to the red, to the max temp. No smoke, no sweet smell, i feel like the fan is kicking on but not always. Not every time the car overheats. No milky discharge in my oil.. no visible leakage of coolant under the car or tailpipe. I'm at a loss for words. I don't know what else to do. Please help!
May 1, 2019 at 4:23 AM
SCGRANTURISMO
  • 4,897 POSTS
Hello again,
Have you check out the water pump yet? There is a weep hole on the bottom that leaks when the bearing goes out on them. You might want to check and make sure that the belt has good tension on it and it not slipping. Other than that I would recommend a flush and fill for your cooling system. There's really not a lot to a cooling system. Let me ask you, when your vehicle overheated in traffic, or when it was idling, did your engine cooling fans come on? Please get back to us.
hanks,
Alex
2CarPros
May 1, 2019 at 5:04 AM
BRITTBRITTD91
I did check the water pump by taking the radiator cap off and gave the car gas and it sucked it in. What else should I be checking about the water pump? The fans do kick on it.
May 1, 2019 at 7:05 AM
SCGRANTURISMO
  • 4,897 POSTS
Hello again,
Like I said earlier, when checking a water pump you want to inspect usually on the bottom, there is a little hole called a "weep hole" which will leak coolant if the bearing in the water pump is going out. Thisi is what you are looking for for a failed or failing water pump.
Thanks,
Alex
2CarPros
May 1, 2019 at 3:52 PM
