air conditioning makes the car overheat?
2006 HYUNDAI ELANTRA
225,000 MILES • 2.0L • 4 CYL • 2WD • MANUAL
YOITSTJ
I cannot run the air conditioning cause it makes the car overheat, however if the car overheats without the air, if I turn the air on then it will cool the engine down. The timing has been changed and I just changed the thermostat and still overheating. Water pump is fine and no leaks from the radiator....
Jul 14, 2025 at 1:31 PM
MECHTRIX
  • 527 POSTS
Do you think its the original 2006 radiator still in the car ? If so id change it ..might be clogged inside and not cooling well anymore ..theres also an upgraded all aluminum radiator thats acually pretty cheap seems to cool quite a bit better than the old version did might want to try that .best of luck ..
Jul 18, 2025 at 8:29 AM
  • 55,423 POSTS
When the engine is cold I would check the coolant level, this is a guide to help as well
https://www.2carpros.com/articles/engine-overheating-or-running-hot
Please go over this guide and get back to us.
Jul 20, 2025 at 3:44 AM
