Going to need more information please, have you checked the coolant level, and can you hear the radiator fan working when the engine is overheating? Please check out this guide to help us get started on fixing the problem:
When in neutral or park the temperature gauge is normal. No fluid leaking, only when driving does the temperature constantly rises until it maxed out. No smoke or noise. This was not gradual, it started immediately.
Apr 27, 2023 at 7:51 AM
✓Experienced Mechanic
Do you hear the radiator cooling fan come on when the engine is hot?
