Overheating
RUBENVALDEZ
  • 1990 CHEVROLET BLAZER
  • 2,017 MILES
Installed crated 350 cubic inch engine in my Toyota now it is overheating changed thermostat, water pump, installed external radiator (small like a heater core) to help the radiator, did not work. Checked head gaskets okay, no leaks in system. I have installed a 15" electric fan 2450 CFM low voltage 9.5 amps, but I am wondering if the radiator is too small the one that is on there measures core 2" with a 3" tank x18" high, 21" wide, two core, side tank top inlets 1-1/2" bottom 1-3/4". I am thinking maybe the radiator is too small. Should I put a bigger radiator with two small electric fans both with 2350 CFM's each?
Monday, January 29th, 2018 AT 12:45 PM
  • 52,797 POSTS
Yes, the radiator is too small. You will need a bigger radiator.
Take the temp of the upper part of the radiator and then the lower end. The temp should be almost 1/2 of the upper temp
Tuesday, January 30th, 2018 AT 9:57 AM
RUBENVALDEZ
Should I install the two 10" electric fans both producing 2350 cfm each?
Tuesday, January 30th, 2018 AT 10:31 AM
  • 52,797 POSTS
With the correct size radiator, no. Are you running a mechanical fan? If not then just use one.
Tuesday, January 30th, 2018 AT 10:59 AM
